Applying G8 textures to genesis (1)
Hi!
I was wondering if there is a way to apply Genesis 8 textures (using the default male or default female UV set, not by means of converting them to genesis 1 uv's) to Genesis 1. It would be a massive saver in GPU memory for a render I want to make if that would be possible, as I could use the same texture maps for all my figures..
Thanks a lot,
Me
    Not G8, but G3 and since they are bascially the same, should work fine
    https://www.daz3d.com/genesis-3-uvs-for-genesis
  • Thanks a lot!!! I'll try that!!!
  • I do have another question about this: The Genesi 8 figures don't come with an option to use the G3 base male or female UV set... I have found products that can let me use M7 and V7 uv's, but no G3F or G3M uv's... Or can I just use a G8 Base Male or G8 Base Female Uv preset and apply a G3F or G3M texture to it? Even if that works, the map transfer tool won't let me convert G8 textures to G3... Again, there is the option of converting to either M7 or V7, but not G3. Can M7 or V7 uv's be applied to genesis1? Or am I missing something here?
    Thanks a lot,
    Me
  • algovincianalgovincian Posts: 2,696
    If it works for G3 acceptably, then it will work for G8 textures.
    - Greg
  • Thanks!!! I figured it out now... Thank you!!!
