Having issue with Daz3d install manager content
My old computer failed and I took hard drive and copied to hard drive of my new computer. Most content is working OK but I am having an issue with some of my DIM content. For example Perrin hair is no longer working. I tried uninstalling and reinstalling but get a "could not open file" error. I've tried to configure everything to go to the D drive but for some reason it is not working. I've tried looking at forums for solution but I don't know what i am doing wrong. I've attached screen shots of the content. Any help would be appreciated.
1920 x 1080 - 611K
1920 x 1080 - 444K
1920 x 1080 - 510K
1920 x 1080 - 461K
  • barbultbarbult Posts: 27,474
    I don't think you are supposed to install files with DIM into the Daz Connect Library. Daz Connect Library is for files installed from within Daz Studio, not DIM. I don't know whether that is the source of your problem. What is the source of the content in all those other librarys you have linked in the Content Directory Manager?
  • Richard HaseltineRichard Haseltine Posts: 111,325
    No, but since the folder has beena dded as a regular Daz Studio content directory it should work even if it isn't the standard set-up.
    One thing to check is that DS doesn'tt hink there's a non-existant Connect install. If you find the item in the Products tab of Smart Content (find the product itself, don't open it to see the files) and right-click on it does the emnu offer Install or Uninstall?
  • OK - I think part of my problem is that I thought DIM and DAZ Connect were one and the same and configured my directories as such. I don't recall whether I orignally installed the product via DAZ connect, as I have generally installed connect manually or via DIM. I originally installed most content manually until I figured out DIM was easier. That may explain why only a small portion of my content isn't working, maybe it is the content I installed via DAZ connect at one time or another.
    Is there a general preferred way to install? DIM or DAZ Connect?
    If I select the content via Smart Content / Product it gives the option to uninstall. It also seems to state it was installed via DAZ Connect.
    However when I attempted to uninstall and re-install I did so via DIM. Is this what is confusing it? I attached a screen shot.
    Thank you both so much for the quick response.
    1920 x 1080 - 625K
  • OK I uninstalled via the right click and I reinstalled via DIM (as most of my other content is installed via DIM). It works for the Perrin hair! I will try that with the other content that isn't working. Thank you so much!
    Good news. You have a better understanding of the installation options now.
