what do I do to get rid of what do I do?
that extra space eating section the refuses to let itself be slid into oblivion.
google won't tell me..  the daz guide doesn't seem to want to and of course searching the daz forum references every post that has any, some, or all of the words {what do I do}
thaniks
  • barbultbarbult Posts: 27,501
    I have no idea what you are referring to. Can you describe the problem with more details.
  • these panels that are part of a lot of the panes...  the white part on the side
    dragging then towards the edge doesn't remove them
    558 x 984 - 113K
    558 x 984 - 113K
  • Richard HaseltineRichard Haseltine Posts: 111,380
    Those will be replaced with the actual working part of the pane once there's something for it to do. If you don't use the pane at all just close it.
    Once you select something on the left side of the panel options will appear on right so you cannot close them because they are needed.
  • duh, got a new monitor and setting up the interface from scratch...  so looking around I see all these panes (other than the scene pane) with all these white things...
    and they weren't stacked into groups where they would be hidden and probably not seen even when opened because they would only be open when they're being used...
    thanks...
    couldn't find a button and the sliding divider wasn't working...
