save as Pose File .pos
KimberSueKimberSue Posts: 353
Hi, I'm working with Aiko 5 and need to save her pose as a Pose File .pos to import for use in marvelous designer. How would I export or save the pose to a .pos?
Thanks
Kimberly
  • Richard HaseltineRichard Haseltine Posts: 111,992
    You can't - that's either a very old Poser format, possibly, or a MD-specific format.
  • KimberSueKimberSue Posts: 353
    Thanks, that is what I thought.
  • JaderailJaderail Posts: 0
    Pose your Figure and Save as OBJ file, be sure you do not save OVER your default obj, load this Obj into MD. You can also try a Cr2 file both can be saved from DS.
    Thanks, I could open the obj figure posed then save as a .pos using MD. What I have is Aiko 5 opened and dressed with the clothing I made. A .pos file is the only file type I can use to pose Aiko 5 to test the clothing movements. While I really only wanted to load poses, MD will take animation file .mdd and probably who I will do this.
  • BlackFeather1973BlackFeather1973 Posts: 739
    I just import the posed obj as a morph target in MD.
    I tried that a few different ways and all I can get is Not compatible with this avatar. I assume Genesis could be the product since it changes into so many different people. I found this in the MD manual. Oh Well.. I'll try it another day. :)
    edited August 2013
    The "Not compatible" error means the posed obj does not match the original obj. For instance, they both need to be at the same sub-d level or they will not match. I also had this error earlier today when i had accidently included a prop in the posed obj (Daz Studio will include everything that is visible in the scene in the obj).
    Edit : if you can't recall the settings you had for the original obj you modelled on, you can also take your posed aiko, reset the pose and export her as obj. Then load that obj as a new avatar. It should fit right into the clothing you had in MD, and it should match the posed obj.
    Post edited by BlackFeather1973 on
    It was a prop like you said. I had hair on one of the figure. Thanks so much.
