"Spring of node..." woes (dForce)
Is there any way ahead of time to determine if an article of clothing not already designed for dForce won't trip up the simulation with excessive "Spring of node" corrections? I can set A value to below the standard 0.20 threshold, but then I never know if the mesh needed it or not for a decent simulation. Also, some other settings particularly related to stretchiness alter the length value to well under 0.20.
It can be a real problem because there's no Cancel button for this popup. Yesterday I sat through 20 minutes (yes, really!) of error corrections, and no way to stop the process. Of course the simulation crashed afterwards. I've taken to simply shutting down Daz and restarting. A cancel button would be better, as well as some method of at least guessing if the mesh is going to be problematic. Ideas?
  • Cancel button. Pretty please! This is so annoying.
  • JpegerJpeger Posts: 25
    I don't want to be the "me too" guy, but... Yes... I'd like a cancel button too. Googleing this annoyance is what got me here.
    OMGERD YUSSSS
  • Late to the party, but since I found myself in here for the same reason as others, yes, a cancel button would be much appreciated.
  • IceCrMnIceCrMn Posts: 2,334
    *raises hand*
    Bartender, I'll take one of those also please.
  • In the year 2026, still wishing for a Cancel button for this process... As I write this I'm ~40 minutes deep into simulation of a ratchet strap around some wine barrels and only at 27% for spring of node 2554500+...
  • Richard HaseltineRichard Haseltine Posts: 111,831
    As has been explained in other threads on this topic, adding a cancel check would slow the process down even with wel-designed clothes - the pain when dealing with items not made (properly) for dForce is understandable but alleviating it would hurt all users even with well designed clothes.
  • barbultbarbult Posts: 27,630
    Why couldn't they add code to just the error handling path? After X number of spring errors, pause and give the user the option to abort or continue. Well designed clothes without spring errors, should not be impacted by code that only gets executed when a spring error occurs. Nobody wants to wait for hundreds or thousands of spring errors. The chance of the simulation working after that is pretty low anyway, I think.
    It has been a long time sine I have touched Windows code as such, but essentially there is an event loop that has to be handled (check to see if there are any commands sent on from the OS that the application needs to respond to). Juggling that in a very short loop, even inermittently, may well be complex and slow realtive to the actual operation being carried out on each loop. I simply can't guess whether a check every soe many edge checks would be workable, nor how much impact it would have on the whole process even in wel-behaved cases; I would think it highly likely that they considered such an option.
    I don't understand how commands from the OS would be involved here. Isn't the check for spring errors performed totally inside the Daz Studio application? Those spring error messages sure come out rapidfire. I don't know anything about the coding of Daz Studio, so I'll just drop this now.
    Intreactions, such as checking a cancel button, do require that that DS process the event queue (the fact that it isn't doing so is precisely what the "not responding" message that appears when you click on an application that is busy with an internal process means). I certainyl can't say that your suggestion is unworkable, but it may well not be that simple to implement and I would think it has been considered internally by the developers.
    I wasn't proposing checking a cancel button on every spring test or even every spring error. I can see how that would be slow. I was proposing that after a certain number of spring errors (tallied by incrementing a counter each time a spring error occurs), that Daz Studio stop and ask (modal dialog) if the user wants to continue or abort. From the outside looking in here, it seems simple and not requiring significant extra processing during the loop of spring tests. Perhaps they have considered and rejected this concept for some reason. I don't know whether they have spent any time on improving a "working" dForce spring test process or not. Waiting tens of minutes for a process to finish, when the finished result is probably not usable anyway, really annoys us users.
  • richardandtracyrichardandtracy Posts: 8,198
    edited January 26
    The event queue could be checked every 1000 loops in the spring check. I've programmed that in my own modeller in the de-triangulation loops and some of the longer & meatier meshing work, like this, based on a loop counter i and remainder function %:
    if ( !(i % 1000)) Application - > ProcessMessages();
    (Code from C++Builder) It saves bucket-loads of time compared to doing it every loop, and allows the user to abort a process that's going haywire. At once per thousand loops, it's not an instantaneous response in some of the longer code (can be i%10000 for faster loops), but it does work rather like the cancel button during a dForce explosion. The cancellation doesn't work immediately, but does work in the end.
    Regards,
    Richard
    Post edited by richardandtracy on
