Creeped out.
I was rendering a scene and this happened. a blood red contusion suddenly appeared. I cancelled the render and checked my original scene. Yea it could be an artifact, but that size location and color? I can't explain this.
617 x 409 - 37K
643 x 467 - 61K
  • 3Diva3Diva Posts: 12,058
    Could it be the hair? Sometimes I have artifacts if a hair's skull cap is interacting with the skin. Maybe try upping the smoothing on the hair and see if that fixes it. You can also try hiding the hair in the scene and then rendering to see if it's indeed the hair causing it or something else.
    edited July 2018
    I get those from the hair from time to time. In certain lights. No biggee. You can easily fix it in photoshop, or change lights. Probably the rim doing it. Sometimes certain lights trigger that...Especially bright ones.
  • FSMCDesignsFSMCDesigns Posts: 12,858
    yeah, kid renders creep me out also, LOL wink
  • kyoto kidkyoto kid Posts: 42,492
    edited July 2018
    ...aww c'mon, Leela's not creepy she's a sweet kid. Now Wednesday Addams, OK she's a bit creepy.
    Post edited by kyoto kid on
  • nonesuch00nonesuch00 Posts: 18,897
    edited July 2018
    Are you using DAZ Studio 4.11.x by chance?
    I am doing a render that is using DS 4.11.x and it's using the Wet Body & Hair Shader product but I noticed that both eyes both have something looking like wounds in the sclera, as well as one temple & one ear have what look like scabs! So I shifted all the models in the scene about so that the character is at location (0, 0, 0) and the "wound" looking render problems are still there, having not changed a bit.
    I have decided I will erase the problem areas with PSE 9 postwork as best as I can muster when the render is done.
    Post edited by nonesuch00 on
  • AllenArtAllenArt Posts: 7,176
    LOL...you're bad ;)
    Laurie
  • KnittingmommyKnittingmommy Posts: 8,191
    One thing you can do is try turning the scalp off. That will fix it. Ideally, the scalp is a back up for the hair, but the hair shouldn't really need it. You should be able to safely turn off the scalp and that will eliminate the red splotches because that is the scalp causing that when the light hits it. Render without the scalp and see if you like how it looks.
  • ANGELREAPER1972ANGELREAPER1972 Posts: 4,905
    looks like some kinda writing maybe she's some sort of clone or synth created  by the  Institute to infiltrate daz world
  • RAMWolffRAMWolff Posts: 10,402
    Wednesday Addams is my kinda child!  Love her so much!
    ...I understand.
    Actually have A Shadowrun RPG character based off her. One of her character Qualities is "sadistic".
  • Joe WebbJoe Webb Posts: 842
    That's just silly. Obviously its the Mark of the Beast. But at this resolution you can't make it out.
    As stated above I'd guess its a combination of the scalp and probably that really bright rim light. Try changing the position of the light slightly.
  • beyonder2k9beyonder2k9 Posts: 117
    it was just the hair cap peaking through the render only. Reduced forehead depth it went away
  • TaozTaoz Posts: 10,381
    Oh, I thought it was the extreme lighting on the hair that was the problem, didn't notice the artifact.
