How do I get Victoria 8's eyelashes to be longer, more curled and more pronounced?
FlortaleFlortale Posts: 611
I have Victoria 8's eyelashes on.  I set the lower & upper lengths to like 50000 and set the curl to 50000, but it's still not long enough, curled enough or pronounced enough?  Anyone know how to fix this?
The eyelashes are too short, even if I set the length to 50,000
These eyelashes are from Victoria 4 which is what I'm shooting for:
I refuse to believe that Vicotira 8 is a downgrade from Victoria 4 when it comes to eyelashes, lol.
Post edited by Flortale on
  • Richard HaseltineRichard Haseltine Posts: 111,420
    Which figure do you have selected? If you've taken limits off the Genesis 8 Female proeprties that won't affect the actual morphs on the eyelash figure.
  • FlortaleFlortale Posts: 611
    edited July 2018
    I removed the limits from Victoria 8.   How do I remove the limits on the actual Genesis 8 Eyelashes?
    This is a huge problem. I can't believe Victoria 8's eyelashes were overlooked.  They're too short the way they are now.
    In the Scene pane click the triangle next to Victoria 8, you should then see the eyelashes. Then you can remove limits on the actual morphs as you did on the Victoria 8 properties - though they may be hidden, in which case you need to enable Show Hidden properties in the Parametrs pane option menu (the lined button in the top corner, or right-click the tab).
    Thanks!
