Is there a way to use the CCT's Transfer Utility with a figure other than Genesis?
Miss BMiss B Posts: 3,071
Up until now I've only modeled props and such, but I've been playing with Marvelous Designer this past week, and came up with something halfway decent. Now I want to be able to use the CCT's Transfer Utility with V4, but the only thing listed in the Source drown-down list is the imported prop of what I created.
I know that Genesis will show up in the list if it were in the scene, but isn't there way to use this with any of the gen4 characters?
If so, I would greatly appreciate it if someone could enlighten me as to how to do it.
FYI, I'm using DS 4.0 Pro.
Thanks in advance.
  • WendyLuvsCatzWendyLuvsCatz Posts: 41,712
    you can, or anything else, if you convert them to triax weightpainting under edit, rigging in the scene tab.
    I do that to add LAMH geometry fur to animals.
  • Miss BMiss B Posts: 3,071
    Ohhhhh Wendy thank you. I saw that option and was wondering what it was for.
    So, IOW, I load up a V4.2 base and transfer her to triax and then she'll show up in the Transfer Utility's drop-down list.
    Thank you ma'am, much appreciated. :coolsmile:
  • BejaymacBejaymac Posts: 2,010
    Converting to Tri-Ax is never a good idea, especially not with V4 as she bends terribly after conversion and her morphs (especially A4 & G4) are a mess.
    yes none of that an issue for me
    as I do so to export fbx into iClone so retargetting of bones happening anyway.
    and only morphs included on that particular character (use current and near vertices)
    Oh I don't plan to use the converted V4 as a character. I just did it so I could start the conversion process of an outfit I created in MD3. I couldn't use the CCT's Transfer Utility because the default V4 doesn't show up in the Source file list. That's the only reason I would do it.
