Is it possible
nonesuch00
I have used SingularBlues G3 to G8 Morph Transfer script to move a set of G3 morphs to G8. It did that OK. However, the set of morphs that were transfered have there own UV set. I have copied and edited that UV set so that it is in the location as the other G8 UV sets & restarted DAZ Studio. However, that UV Set is not showing in the list of UV Sets in the Surfaces dropdown.
How do I do that correctly?
That is a different kind of transfer. You could use map Transfer to make versions of the maps using the base UVs, or you could create a new UV set in a suitable editor, or you could use:
https://www.daz3d.com/genesis-3-character-uvs-for-genesis-8-male
https://www.daz3d.com/genesis-3-character-uvs-for-genesis-8-female
OK, thanks. I was finally checking into the capabilities of the old SingularBlues scripts from way back on JoeQuick's Toon Duckie for G3M. It actually worked good except on what looked to be the easiest part with the fewest extreme morph changes - the arms. So after that Toon Duckie morph set transfer is done it has it's own UVs and I wanted to transfer them to G8M too.
I will try the map transfers from G3M Toon Duckie to G8M Toon Duckie.
