Unable to texture Imports from Blender
Hello,  I create a mesh and add a material in Blender 2.79.  I import it into the latest version of Daz Studio.
Under Surfaces, I select an image for Difuse.  The color displays but the actual grain does not display.  Nor does the bump when I add a Bump map.
This occurs when the mesh is imported as .dae, .fbx, and .obj.
Does anyone have suggestions?
Thanks
1086 x 1050 - 120K
    Hi! Blender procedurals do not export to DS. You will have to bake the materials to your UV maps and save a diffuse, bump, etc. To .jpg format and then load in surfaces tab channel by channel.
  • Does this apply when all you want to do is use the Iray shaders in Studio?  I only used Blender to delineate the material zones, planning to apply the shaders in Studio.  I get color and shine when rendering, but none of the patterns that, when I look under the Surfaces tab, the program says are there.
    It's my first attempt at a full room, so I'm certain I missed a step somewhere...
  • WendyLuvsCatzWendyLuvsCatz Posts: 41,509
    sounds like it has no UV mapping in DS
    Yep!  That was what I didn't know that I didn't know, hahaha.
  • RARA Posts: 78
    Thanks very much for the responses. Will follow up with UV mapping in Blender
