Pivot
Does DAZ Studio have a Joint Editor or something similiar for placeing a marker to pivot or rotate an object around a point or swing backs and forwards for example such as a swing or a punching back? Cheers
  • Richard HaseltineRichard Haseltine Posts: 111,965
    Tools>Joint Editor, the default,behaviour is editing the Centre/end ppoint - the Window>Panes(Tabs)>Tool Settings gives options, and numeric controls.
  • Syrus_DanteSyrus_Dante Posts: 983
    The pivot point could also be a Null or a Group object from the Create menu. You can parent individual items, objects whatever to it with the Parent To action or the drag and drop in the Scene pane - take care of the Parent Items In Place option in the Scene pane options menu (the lined little button on top). If you now move, rotate or scale the Null or Group all parented items follow along with it as center or pivot point.
  • Many thanks.Now how do I get rid of the tool off my interface? No matter what I try it will not go away! Cheers
  • Pick a different tool from the tool bar or Tools menu.
  • Many thanks for your replies.I clicked on the arrow tool and that fixed the problem! Cheers
