Issues with installed content
Using the new installer some items are always missing files and I cannot use them, is there any way to run a repair or find a way to fix this. I let it run to the default but this keeps happening.
    Depends what the item is and how you're trying to access it. If you're using Smart Content, not everything will show up as not everything has metadata yet. Some things are also in Poser format and can only be found through the Poser Format heading in the Content Library tab.
  • fixmypcmikefixmypcmike Posts: 19,729
    Can you name some specific items, and we can check?
  • ManStanManStan Posts: 0
    This is why I like zips or installing to a dummy folder. You can check to make sure the items is all there before dropping it in you library folder.
