Lights Showing
When I go to render a secene with 5 spotlights the spotlights render with the scene as black squares. Can anyone suggest what I an doing wrong? Cheers
  • Richard HaseltineRichard Haseltine Posts: 111,958
    I think you are in Iray and seeing the emitter from behind. If so, select the lights and in the Parameters or Lighting panes set render Emitter to Off. Note that this affects only the direct line-of-site, viewed in reflections or through other surfaces the light source will still be visible.
  • Many thanks for help.Cheers
