Craziest thing happened during IRAY render. It restarted rendering 8 minutes in.
FlortaleFlortale Posts: 611
I was doing an IRAY render and I was eight minutes in.  Then the iterations started from the beginning again during the render.  It's like it just automatically restarted? Anyone know why this happens and how to prevent it?
  • Richard HaseltineRichard Haseltine Posts: 111,382
    What are your current render settings/ If you check the log (Help>Troubleshooting>View Log File) is there a message relating to the restart?
  • BeeMKayBeeMKay Posts: 7,019
    I had this happening when the render switched from GPU to CPU for whatever reason, but that should be in the log.
    It happens properly when you change certain settings during render, like render quality.
  • FlortaleFlortale Posts: 611
    I'll check the log as soon as it happens next time, that should explain things, thanks
