Question about skins
valtiel2003valtiel2003 Posts: 0
I have the following skins.
V5 bree skin: http://www.daz3d.com/victoria-5
Tori: http://www.daz3d.com/tori-for-v5
Gabi: http://www.daz3d.com/gabi-for-v5
But when it comes to putting a mat on the v5 genilatia it only promps me for V5 bree and Gabi but not tori.
Why not tori? None of those 3 say anything about genitalia mats on the description anyway, that's why I'm asking. Can someone point out the difference between Tori and the other two, what is she missing?
And while we're on the subject, what does bree mean?
    edited August 2013
    I can't help you with the gen mats, but Bree is a name (usually short for something like Brianna or similar).
    Post edited by Lissa_xyz on
  • JaderailJaderail Posts: 0
    edited August 2013
    Bree is the Default V5 skin Vask.
    Here is how to use a TEXTURE on the gens. Select the Gens, in both Scene and Surfaces Tab, last part to be safe, now go to your texture, and apply the FULL body texture just like you would for a figure. Then be sure the correct UV is used. Ta Da, your done.
    Post edited by Jaderail on
    edited August 2013
    I know what Bree is, I have V5; she's also the default texture for G2F.
    He asked what Bree meant. I took that in assuming he was looking for a definition as if Bree was in the dictionary and not a girl's name.
    Bree is a name, I have a niece named Alicia Bree "BLANK, not telling", I figured most knew it was just a given name.
    I did miss that part...
  • Scott LivingstonScott Livingston Posts: 4,352
    'Derived from Irish brígh meaning "power, high."'
    http://www.behindthename.com/name/bree
  • WendyLuvsCatzWendyLuvsCatz Posts: 41,696
    as opposed to Brie which is a soft cheese!
    (and what I thought of when I first heard the name years ago!)
  • valtiel2003valtiel2003 Posts: 0
    edited August 2013
    That works fine except theres a black patch in at the very bottom of the crotch for some reason, right in between the "front and back door".
    The skin I have right now is http://www.daz3d.com/fw-julianna and there isn't a uv option for that...
    What do I do?
    Post edited by valtiel2003 on
    she would use V4 uv mapping, prob a Gen crease morph would work better
