Cannot find Dolphin !
AJ2112AJ2112 Posts: 1,417
Hi friends, just purchased Dolphins from store. Used Dim. I cannot find dolphins anywhere in content library. Installed files list shows dolphins at Daz Animals. Nothing. Uninstalled. Reinstalled with Dolphin exe, still same thing no dolphins. Attaching image of installed files. Thanx.
336 x 179 - 130K
  • JaderailJaderail Posts: 0
    edited August 2013
    It Shows as Poser Formats>My Library or My DAZ 3D Library>Characters>Daz Animals>Dolphin
    This will be using ONLY the Content Library TAB.
    Post edited by Jaderail on
  • AJ2112AJ2112 Posts: 1,417
    edited August 2013
    Thanx buddy. Found it under Poser figures, after restarting Daz. Oh great, no morphs for dolphin. Now I need dolphin pose pack.
    Post edited by AJ2112 on
    It actually says it has head morphs and is fully poseable. You may need to extend him down the scene tree to get to everything.
    Thanks friend. Only head morph, no pose adjustments :-)
    edited August 2013
    For pose adjustments you most likely need to select the bone, and then use the normal rotate/twist/bend dials in the General section of the Parameters tab.
    A tip too, if you're editing connected bones (say a finger, or a tail) you can select all of them at once, and bend/twist that way. That way they all bend together and look accurate.
    Post edited by Lissa_xyz on
    Thanx for the tip friend. Don't think dolphin is pose adjustable, reason for dolphin pose pack in store.
    Although it is not very posable it does have posable parts.
    THis is how they show in Poser, not sure where they would be in DS
    322 x 219 - 59K
    Pose packs are just pre-done poses with what's already available, meaning you can get those same results without the pack and a little work.
  • Richard HaseltineRichard Haseltine Posts: 111,958
    If the dolphin didn't pose there couldn't be a pose pack.
    Thanx friends, for assistance. Figured it out. Ding dong me. Didn't even think about sub catergories (individual parts),. Fantasy dolphin scene in progress :-)
