Xurge3D outfit Readme file installation
Hello!
I purchased an outfit from Xurge3D, I heard it's possible to work on DAZ3d program too (I know they are doing products for Poser), the problem is that I only got a "Runtime" folder, and I copied it to "My DAZ 3D Library" but I can't find it anyqhere in Daz3d. I purchased things from Renderosity, and all the elements were listed in that folder. How do I proceed to use this outfit?
Thank you!
  • Richard HaseltineRichard Haseltine Posts: 111,659
    Look in the Content Library pane, under Poser Formats>My Daz 3D Library>Figures - the folder should have Xurge 3D and/or the name of the product. There will probably be materials in the Poser or Material library too, and possibly props in the Props library.
  • I am using DAZ3d, not Poser.
    And I can't load the file, it's just a runtim folder..
  • Hello!
    Thank you!
  • LeanaLeana Posts: 13,553
    The content is in poser format, that's why there is only the Runtime folder: all files to load the content are inside the Runtime structure. As Richard said you need to look in the "Poser formats" section of your content library in DS to find them.
  • Ok, I had to link the folder, because I changed the file directory. Now I found them, but nothing fits to any character. Why is this happening? Not only for Michael 4, (which is made for that character)
    Can you elaborate?  What do you mean when you say it doesn't fit, is there poke-trough in some places? Or does it simply not conform to M4 automatically? Did you use a base M4 figure or a morphed one?
    You may find it helps if you unzip the file from Xurge3D to a temp folder and then merge the runtime folder with your existing runtime folder, or else just copy the contents of the runtime folder and paste it into your existing runtime folder.
    merged duplicate threads and moved to Daz Studio forum
  • So, I purchased an outfit from Xurge3D (in fact 3 outfits), they say that are made for Michael 4, I purchased Michael 4 too. Nothing is working. The clothing isall wrong, nothing ftis on the character. I wanted it to fit my Genesis 8 characters, but I guess there's no luck in such thing?
    I have attached the print screen with Michael 4, and also with another Genesis 3 male character...I tried everything, it just doesn t fit at all.
    3834 x 1962 - 638K
    3822 x 2013 - 675K
    edited July 2018
    I have never had any problems with Xurge stuff, although admittedly I do use Poser,  but I also know others who use Xurge outfits in DS.  In Poser I just load the clothing and use the conform to  command  (which I think is the equivalent of fit to in DS.)   that doesn't look like an outfit I have though.
    However I do notice that you appear to be trying to fit a V4 clothing item on to M4
    Post edited by Chohole on
  • If I install Poser, can I convert all my characters and clothes that I bbought, to use them?
    Does Poser render as good as Daz3d?
    That isn't necessary. As I noted in my reply to your initial thread, you can find the content listed in DS under Poser Formats and it will work (materials aside in soem cases, an dvery occasionally morphs aside). Are you sure you are merging the Runtime from the zip with the Runtime in the My Daz 3D Library folder?
    edited July 2018
    That's a V4 outfit, not a M4 one, so it's perfectly normal it doesn't fit M4.
    You could autofit it to G3M if you have this: https://www.daz3d.com/wear-them-all-autofitting-clones-and-clothing-smoothers-for-genesis-3-male-s or to G8M if you have this: https://www.daz3d.com/sy-victoria-4-and-michael-4-clones-for-genesis-8
    But there's no guarantee it would look good on a male figure since it's a female outfit.
    Post edited by Leana on
    Yes as I said earlier, that outfit is for V4 not M4,  and it would appear that the other Xurge outfits shwoing in your images, one is for M3   and on the last one is actually an M4 outfit.
  • OMgosh!!! I purchased the 2 extensions, and everything worked!!!! I am sooo happy! Yes, I realized I was using the V4 to a male model, but it was the same thing for the M4 outfit. It didn't fit at all.Now everything orks perfectly!!!
    Thank you so much guys! Appreciate this a lot! I have one more quesitons (sorry), do you have any idea if I am allowed to use the outfits from Xurge 3d, in commercial artworks? as Daz3d allows? (Book cover art for example, premades etc)
    Thank you again!
    AFAICR   yes the readme is similar to Daz,
