How do you tile the bump map, but not the base color map?
I want to tile the bump map and not the base color map.  Is there an easy way to do this?
  • barbultbarbult Posts: 27,500
    For Iray Uber Shader, Right click on the bump map image thumbnail in the surfaces pane. Select Image Editor. Then set Instance Tiling.
  • FlortaleFlortale Posts: 611
    Thanks!
    I think it's right click. I'm going from memory, because I'm not at the computer. If that isn't correct, try regular old left click. wink
  • Richard HaseltineRichard Haseltine Posts: 111,374
    Left-click opens the menu
    Thanks Richard.
