About to be a new user, But have a couple Questions?
JennKJennK Posts: 834
I am about to be a new user to Carrara but I am on a limited budget and at this time can only afford the standard version. Can someone tell me the major difference between the standard and the pro? Also is standard a good jumping off point with hopes to upgrading later?
Thank you so much.
  • GarstorGarstor Posts: 1,411
    http://www.daz3d.com/products/carrara/carrara-tech-specs/
    That details pretty clearly what is in Pro versus Standard. One big thing to note, 64-bit support is Pro. Ditto for the bullet physics stuff (which is admittedly still buggy).
  • 3DAGE3DAGE Posts: 3,315
    HI JK0011
    This may sound strange, but the Standard version will function as the Full Pro version with all the tools for the first 30 days.
    then it'll revert back to Standard,.
    and the icon's and function of the pro version will disappear.
    This gives you the 30 days to evaluate and get an upgrade / return
    Also,.. The Trial / Demo version operates in the same way,. so in theory you could Try out the Pro version in the Demo for 30 days, then get the Standard or Pro.
    The demo/trial is available at www.download.com
    There is a features Comparison chart in the Carrara section. here...
    Hope it helps :)
  • JennKJennK Posts: 834
    Thanks Garstor and 3DAGE. that helps out a lot.
    Pro boosts certain workflows (it's not always logical, but more or less) in 3 main categories:
    modeling - additional tools in the vertix modeler, 3D Paint, UV Map tools
    animation - global illumination baking, animation grid, negative lights, normal maps, render farm, Ocean
    import/export - FBX output, LWO import, motion tracker
    If you are a new user, it might be a while before you are ready for Pro features, but if you want to animate will will probably want Pro sooner.
  • RomancefantasyRomancefantasy Posts: 0
    Like 3dage said, it would be wise to download the demo of Carrara and try it out first. Carrara 8.5 is in beta now and should be finished SOON. Daz usually has a nice sale when they release a software upgrade so if you time it right you could save a lot of money on an upgrade; unfortunately there is no hint of when to expect C8.5
  • HeadwaxHeadwax Posts: 10,562
    I had a bug report that got cleared after 14 months last week with no comment.
    (turns out it was user error)
    When I 'complained' Richared Haseltine said it might be because they are about to issue Car 8.5.
    Because clearing old b ug reports was something they did before releasing a new 'version'.
    Note I said 'might' :)
