Conform clothing to very small chest
Hi,
I was working with a Sakura 8 figure that has the smaller bust.  A bunch of the clothing has a collapsed look surrounding the breast area with a ridge running down where the cleavage area is.  How do you make clothing items like the basic tank top fit a very small busted figure?  Is there something I need to adjust or turn on?
thanks
  • Richard HaseltineRichard Haseltine Posts: 111,816
    This is a typical problem the projection of morphs (if there isn't a custom shape in the clothing) does not tend to work well for reduction. You could try selecting the clothing and applying a Smoothing Modifier (Edit>Figure>Geometry>Apply Smoothing Modifier), assuming one isn't already applied, and in the Mesh Smoothing group in the Editor tab or the Parameters pane set the Smoothing Type to Generic (instead of Base Shape matching). Applying a dForce modifier and draping might also help, assuming the clothing will work with dForce. SickleYield, Zev0, and others have products designed to help with this kind of situation though again the results will vary. If those all fail it's a matter of creating a custom morph - for example you could send the mesh over to hexagon, apply soem smoothing with its tools, and send back to DS as a new morph.
