Help with error 0xc000007b
versora_vincent
I keep getting the error in the title of this post. This program is not worth my time. I may as well save up the 500 bucks it takes to buy Poser. I never had this problem until now. and yes I did the whole uninstall reinstall reboot. Nothing worked.
Post edited by versora_vincent on
More information would help. I assume this is a runtime error you get when starting Daz Studio? If so it would help if you posted your system specs, and if not then it would benefit to know where this error occurs.
We may be good but I do not believe we all know the Error codes from memory. As HOF says more information is needed.
ASUS G57V Republic of Gamers gaming laptop
Windows 7 Home Premium Service pack 1 OS
nVIDIA GEORCE TGX 660M 2GB video card
Inetl Core i7
1 TB hard drive
Last time I checked I have no problems running any programs I wish.
The message is a DAZ.exe error by the way
Sounds like those OLDER Needed Library files for MS are not installed. I'll drop a line to the other Admins as I do not have a quick link to them at this time.
Just one more Question, whats your Total RAM?
Assuming no upgrades, you should have 8Gb RAM which is more than ample to run Daz Studio. This error can occur when you're using a 64-bit version of the software on a 32-bit operating system, but I'm going to assume you have the correct OS for your laptop. You can check this yourself by looking at the system information in the control panel.
Are you trying to use the 32-bit Daz Studio or the 64-bit version?
The best I could find on this problem was here
Microsoft help forums
