Install manager question
grpruettgrpruett Posts: 255
I bought haunted mansion and the haunted mansion has a file for Bryce 7. I do have Bryce 7 so that's not a problem, but I don't have an installation path to Bryce.
When I set the path for Bryce, is there a specific folder I should be mapping to?
  • fixmypcmikefixmypcmike Posts: 19,738
    edited July 2013
    On the Settings > Application tab map the folder containing Bryce.exe -- I believe the default is Program Files\DAZ 3D\Bryce7 on 32-bit Windows and Program Files (x86)\DAZ 3d\Bryce7 on 64-bit Windows, although I install Bryce outside of Program Files just because Windows can be overprotective.
    Post edited by fixmypcmike on
  • JaderailJaderail Posts: 0
    On the Settings > Application tab map the folder containing Bryce.exe -- I believe the default is Poser Files\DAZ 3D\Bryce7 on 32-bit Windows and Poser Files (x86)\DAZ 3d\Bryce7 on 64-bit Windows, although I install Bryce outside of Program Files just because Windows can be overprotective.
    LOL!! Um... POSER FILES? Read that as Program Files for both. And As stated Bryce preforms better if installed outside them. I did it as well.
    Oops :red:
    I actually have all my Bryce versions installed on a separate drive,
    And I never allow installers to install Bryce content themselves, I run them to a temp folder and drag and drop stuff over myself.
    However Horo has done a very useful PDF to help people make sure the content is in the right place
    http://www.horo.ch/docs/mine/pdf/BryceContent_v4.pdf
