shopping cart!(Solved) But V4 for Gemesis 2 Seams are Bad.
Sal UK
I tried to put in V4 for genesis 2 female into my cart it didn't show up in there and now if I try I get "The maximum quantity allowed for purchase is 1."
This is getting rather silly now I even tried from my 2 computer systems and still happens..
Steve.
Post edited by Sal UK on
1. Make sure you are logged in.
2. Put some other item into your card (doesn't matter which one, it won't stay for any long time)
3. Open your cart and delete the new item.
4. Now the cart should show your previous item correctly and/or allow you to add a desired item without problems.
It is a known issue that arises when you put something into your cart while not being logged in.
Thanks Kattey ill give that a try but I was logged into the store at the time. :)
steve
Thanks again that seems to have fixed it.. :)
Though the messing around because daz haven't updated materials to duf is a pain and the seams have problems too.. :(
You might think that, but the store sometimes isn't so sure. Check the Cart and Wishlist counters, up at the top of the page above the search box, if that suddenly goes to zero then the store's forgotten your login session again. It happens to some people occasionally... and more often than that to others. :-S
