Bethany 7 skin issues?
mats76mats76 Posts: 296
I just noticed that the Betany 7 skin gets a weird issue under the breasts when applying morphs that reduce the breasts, it almost looks like bad scars. Same thing happen if I just remove the bethany 7 morphs so  it is just basic G3F with Bethany 7 skin.
Is this an old issue due to the different UV? or is it a new one connected to the G3 essentials uppdate as I have not noticed it before?
Post edited by mats76 on
  • Richard HaseltineRichard Haseltine Posts: 111,325
    Try removing the normal maps, I think there should be a materials preset to do that. The normal map sets the direction in which the surface is treated as facing, for the purpose of determining how much light hits it, and the shape adjustment is changing the actual facing of the skin - the combined result is, as I recall, odd shading.
  • mats76mats76 Posts: 296
    Thank you for your super quick reply, much appriciated. It worked perfectly.
