Plugin Failed To Load
I bought Decimator  1.8.0.123 and when I install from DIM , it installs fine but in the "About Plugins" it says "Plugin Failed to Load"
When I install manually , it says "That it can't find the Installation Path"
I tried a RegEdit solution that I found online but that fails as well.
Is Decimator an abandonded product? because if it is I will want a refund.
  • Richard HaseltineRichard Haseltine Posts: 111,325
    Are you using the current version of DS, 4.10.0.123? The Daz-branded plug-ins are specific to the DS version released at the same time. My copy is working with the .123 versions of DS and Decimator.
