Daz Studio and Install Manager freeze up if run on second monitor
Hey
This is more of a bug report than actually looking for a solution (since my solution is typically just to disconnect my second monitor when i boot up DAZ if i left DAZ open on the second monitor).
However, if you start up/boot up either DAZ studio or the Install Manager on a second monitor, they will as the title say freeze up and become unresponsive.
This only happens on the second monitor (the one assigned as 2), and the same happens if i switch the monitors (which rules out it being a problem with the monitor itself).
You can still start em up with both monitors connected, but only if they start on the monitor assigned as the main monitor.
Thanks.
Bug reports should be made via a Technical Support ticket https://www.daz3d.com/help/help-contact-us
