Decimator for DAZ Studio not shown in panes
I just bought the Decimator for DAZ Studio from here https://www.daz3d.com/decimator-for-daz-studio, but I can't see the feature inside Daz Studio. I thought there would be a new entry under menu Window > Panes (Tabs), but nothing related to decimation. I checked the Daz install manager and the plugin shows there as being installed (Decimator for Daz Studio 4.10+ Win 64-bit). I tried to download the file and install it manually but, even though the installation completes without a problem, I get the same luck. Any suggestion to make this option visible?
Thanks
  • ocapvrocapvr Posts: 1
    Here is an update. I found out that I had to enter the serial number. In the About Installed Plugins window, I can see two entries for Daz Decimator, both of them are Disabled. In one, there is a text box to enter the serial number, it validates it. I restarted Daz Studio, but the status of the plugin doesn't change, still showing as disabled.
  • NorthOf45NorthOf45 Posts: 5,908
    I only have one entry for Decimator, so maybe adding it manually interferes with the installation and validation. Try starting over, using the DIM install method and entering the serial number for the, presumably, single entry.
