How do you fix lighting in preview (work window)
Basically, I've loaded an environment and lights that I want. In the Aux port, they light and show up in Iray preview beautifully.
But in my main workspace everything is too dark, I can hardly see the character, and can't navigate the scene at all. I use texture shaded for this while I work.
I have preview lights on, no idea what I may have altered to cause this. Thank you.
  • FishtalesFishtales Posts: 6,238
    Try Ctrl/L and see if that helps.
  • DefaultNameDefaultName Posts: 444
    I can see the figure now, but the background is still dark. Thank you so far, I don't know what ctrl/L does, I thought I had the poreview lights on.
    If you are using a camera, rather than a perspective view, try turning the Headlamp on under the camera settings..
    Oh, good idea, okay
  • Richard HaseltineRichard Haseltine Posts: 111,996
    ctrl L toggles the light preview on and off - it's on by default, so the first press turns it off and just gives a generic headlamp (without having to have the Headlamp on).
    You can turn the headlamp off entirely in the General group in Render Settings.
  • guy1guy1 Posts: 6
    Try adjusting the intensity of your scene lights until the preview looks good. The adjust ISO in render setting until the renders look good.
