Getting stuff to show up in Smart Content
retiretomaui
in The Commons
Hi,
I'm hoping someone can give me a solution or a few hints. I have a ton of content, mainly older V4 stuff, that shows up in Content Manager but not in the Smart Content pane. From nosing around, I'm guessing there isn't metadata for it, or whatever is needed to get Daz Studio to categorize it into the Smart Content pane. I rarely use Content Manager and tend to rely upon the Smart Content pane. So... Is there a way to get these items (things like Technophilia come to mind) to actually show up in Smart Content?
Thank you!
Bob
It‘s tedious and a lot of work, but it can be done. You have to create metadata for each piece you want to show up in smart content. I found this tutorial to be most helpful so far: https://www.youtube.com/watch?v=r-sdHEBNCB4
Hope that helps!
Thank you, I"ll give it a try!
You just have to remember to export all of your custom metadata before upgrading then re-import it after.
You can just drag and drop the items into smart content menus/categories now (for your own use). Let say that you have content library tab opened on your right side and smart content tab opened on your left side. So grab item from content library, drag it over to the smart content tab and drop it On the menu you wish item to be in. A window will appear in which you assign content type and after clicking accept its done, item is in your smart content now. If you wish to assign items to the specific figure, like, for example, clothing to the G8F or poses for G8M, you need to have that figure (G8F or G8M) loaded in the scene and have it selected in the scene tab before you start draging and droping items
How did you create the visual catalogue???
Thanks for the tip, Ben.
