More issues with studio
ManStanManStan Posts: 0
I am still running in to issues with Studio.
I load V4, go to poses, inject the base morphs, it runs through the applying, inject morphs++, and it runs through the applying, no errors at all, no mophs ether. As in no morph sliders are added. I've also tried the SP4 and elite morphs. Nothing. It goes through like it is applying them, but doesn't. They apply fine in carrara though, so it's not a placement or content issue.
  • Richard HaseltineRichard Haseltine Posts: 111,984
    Are you using the Power Loader dialogue? If so you shouldn't need to inject the morphs. Are you sure you have the same content directory set-up in Carrara and DS?
  • ManStanManStan Posts: 0
    No powerloader, Studio and carrara are using the same my library.
    If you load V4 and enable the display of Hidden Parameters (Parameters pane option menu) do you see greyed out channels, with the name prefixed with EMPTY, for the moprhs? (Which reminds me - the morphs won't appear in the Shaping pane, you do I think need to use Parameters.)
  • SzarkSzark Posts: 10,634
    Could be the same issue as this http://www.daz3d.com/forums/discussion/26194/ where I advised...
    Szark said:
    And this is on a newly loaded V4?
    Also when you installed the morphs did you run the DzCreateExPFiles-V4.bat file to initialise the morphs?
    The .bat should be in your content folder in Runtime\libraries\!DAZ just click/double click on it to run. Once run try again on a newly loaded V4.
    I love Powerloader for Daz Studio. ;)
    WOOT That got it, thanks Szark.
    Excellent. :) Thanks for letting us know.
