New 64bit DIM thinks all my daz library is not installed
greymouser69greymouser69 Posts: 501
Just upgraded to the new DIM (removing my old 32bit one) and when I get it logged in it thinks nothing is installed anymore.  Any way to fix this?
Edit: correction it thinks almost everything has updates. Ok just some had updates most are not showing as installed.
Post edited by greymouser69 on
  • NorthOf45NorthOf45 Posts: 5,912
    I upgraded mine a couple of weeks ago and had no problems. DIM looks in the manifest folder (usually in "Users\Public\Documents\DAZ 3D\InstallManager\ManifestFiles") to see what is installed every time it starts. There should be a .dsx file for every installed product file.
  • greymouser69greymouser69 Posts: 501
    I checked the DIM thread in Commons and there were several people reporting the same behavior on the 64bit version.  The workaround seems to be to install the 32bit one which I did and it shows everything correctly.
  • Richard HaseltineRichard Haseltine Posts: 111,677
    Had you edited the path for the Manifests folder? Not that that should be an issue, mine works properly, but it might be a factor.
    No not at all, my manifest files are in C:\Users\Public\Documents\DAZ 3D\InstallManager\ManifestFiles but for some reason the 64bit version isn't seeing them while the 32bit works just fine.
