SOLVED! Everything Below Ground Renders Invisible
xyer0xyer0 Posts: 6,505
I have a template scene that has inexplicably developed an issue: Everything that is below ground level (floor) does not render. The transparent, that is, nothing is all that's there. Even with nothing in the scene but a character. Any ideas?
Post edited by xyer0 on
  • Mart1n71Mart1n71 Posts: 132
    In the 'render settings' tab, under 'enviroments', is the ground position node set to manual? if so change it to auto.
  • TooncesToonces Posts: 919
    Also in Environment, you can set Draw Ground to Off.
  • xyer0xyer0 Posts: 6,505
    It WAS set to manual! I changed it to "Auto," and I'm awaiting the result.
    I usually have Draw Ground set to Off because I rarely use the ground of the HDRI's.
    @Mart1n71 Thanks! That did it! I must've loaded something that included that setting, and it stuck. @Toonces Thanks to you, sir/madam!
