What's Going on with Morningstar Wings for G3 and G8 Male?
I just tried to load the Morningstar Wings on G8M and the Auto-Fit prompt popped up.  What gives?  If it's designed for G8, then it should work out of the box.  On top of that, it doesn't even have a choice of "originally designed for Genesis 3 Male", just G3F.  If I let it auto-fit, it attaches itself to his arm movements, so if want his wings up, I have to move his arms.  That's a little weird.   Am I missing something with this product?
  • JoeQuickJoeQuick Posts: 1,735
    edited July 2018
    I don't have the product, but I would not use autofit.  My guess, if you're prompted to autofit, just click cancel, or x or something along those lines, then parent the wings to the figures back (chest), I would imagine they have their own bones for posing and things, and those bones would be destroyed in the autofit process.
    But again, that's all just conjecture.
    Post edited by JoeQuick on
  • I took the G8F wings, changed the identifier to G8M, and it fit okay to Floyd 8...
  • nemesis10nemesis10 Posts: 4,014
    edited July 2018
    Try a deinstall and reinstall..  I testing mine out and it should work like any other bit of anatomy.
    1631 x 1229 - 856K
    Post edited by nemesis10 on
  • sandmanmaxsandmanmax Posts: 992
    Ok.  I'll try that.
  • ChangelingChickChangelingChick Posts: 3,441
    Each set comes with a G8 and G3 version for the gender the set is for. You could have just selected the wrong one to attach. I've been using them a lot lately, and haven't run into any issues.
    edited July 2018
    Many of the wing sets in the DAZ store aren't really "for" any specific Genesis (or the older Unimesh) generation — they aren't supposed to be conformed, like clothes or hair, instead they're parented like a prop. In this case, what you do is load the wings without the figure selected (this avoids invoking Autofit, which can strip out wing-specific morphs and movements), then parent the entire wing object to the figure's Chest. Note that the last couple of Genesis generations have an Upper and Lower Chest; the wings should be attached to the Upper Chest (since they're usually supposed to be growing out of somewhere about the shoulder-blades). When you have the wings parented, you can use the base wing body — not any body part — x- y- and z-translate dials, plus any fitting dials there might be on the wings, to nudge them into exactly the position you want.
    Post edited by SpottedKitty on
