Weird Autofit Problem - everything is 'unsupported'
Due to disk space issues on C:, I set the DAZ content path for all my content over to E:.  I reinstalled all my content via Installer, and moved over all the Library folders - there are no C: paths still in content management.
Everything seems to work fine, except autofit.  If I try to put a G2 outfit on a G8 character, or any similar issue, autofit only brings up 'Unsupported' as the source.
I have all my content installed, so everything from M4/V4 to G8 is available.
I assume there's some odd inconsistency that I'm running into - any bright ideas what I need to tweak?
  • Richard HaseltineRichard Haseltine Posts: 111,332
    Is the Content Management System working - do items appear in the Smart Content pane, and in the Categories and Products list of the Content Library pane?
  • Yes - all the content shows up properly.
  • murgatroyd314murgatroyd314 Posts: 1,569
    First thing to check: make sure you have the figure itself selected, not (for instance) a piece of clothing on the figure. That's usually what's going on when I have this issue.
    If that's not it, make sure the autofit clones exist. Parameters tab, show hidden properties, look in [figure name]>Hidden>Clones.
  • Nope.  There's no hidden properties at all.  I compared to a working install on a different machine - there's a couple sections missing entirely from properties, both 'Hidden' and 'Pose Controls'.  Same situation on Genesis 1, 3, and 8 - figured I'd check all of them just to confirm.
    Is this something fixable, or am I at 'wipe and reinstall'?
