Clothes exploding while loading scene
ZenrelZenrel Posts: 245
Why some clothes that is being used in a scene tends to explode after loading a saved scene? I was using fairytale and magna hart, both made by bobbie25.
  • Richard HaseltineRichard Haseltine Posts: 112,078
    Was the scene originally created in DS 4.0 or 4.1, and is it now being opened in 4.5 or 4.6? if so, try saving the scene (as a .duf file, it won't overwrite the original) and see if that now opens correctly.
  • ZenrelZenrel Posts: 245
    It's created in DS 4.6 and saved under .duf.
  • TotteTotte Posts: 15,316
    Check what subdivision algorithm you are using, some clothes doesn't work well with the newer methods. Try to set it back to legacy smoothing (Catmul Clark)
    Where can I find this subdivision algorithm?
    Here:
    Select Genesis, then goto parameters..
    432 x 335 - 43K
    edited July 2013
    Thanks Totte! No more exploding clothes!
    Post edited by Zenrel on
  • RogerbeeRogerbee Posts: 4,460
    Much as I hate digging up old threads, I had a similar problem but with the B25 boxers. This thread came up in a search so here we are...
    Changing the smoothing on the figure to Catmul Clark did seem to help, until I reloaded the scene to check on something after I'd opened it moments before, lo and behold, the boxers exploded again. So, I looked at the smoothing type on the clothes and changed that to Generic and so far so good.....
    CHEERS!
