daz crashing
fairyfantasticfairyfantastic Posts: 116
hi all just wondering has anyone else having problems with daz4.6 crashing mine has started just recently mainly sice i installed gen 2 its a pain wen im trying to do renders or save stuff in daz thn it crashes is there a way to solve this please thnk x
  • Richard HaseltineRichard Haseltine Posts: 111,478
    32 or 64 bit version? Is there any pattern to when it crashes?
  • fairyfantasticfairyfantastic Posts: 116
    its 32 bit hun it crashes wen im either half way through doing things eg importing or making a render i get so far thn it just decides to crash
  • DoctorJellybeanDoctorJellybean Posts: 10,121
    Start DAZ Studio, click Help - Troubleshooting - View Log File. It should open in your default text editor. Save it somewhere, browse to where it is saved in Windows Explorer and attach it.
  • ecoleenaecoleena Posts: 85
    edited July 2013
    Even my 4.5 (64 bits) version crashed endlessly, too.
    Just to put in scene a grey genesis with a hair with morph, and
    only tweaking a little bit with morphs buttons, causing crash.
    I resolved with an advise i saw in this forum:
    I don't know who it was, ( i was almost sleeping on my keyboard-in the middle of the night)
    but i want to thank him alot !
    In menu of Daz :
    Preferences / Display / BETTER (instead of best or off).
    I really hope it could be useful for you.
    Cheers
    Post edited by ecoleena on
    thnks loreleen teied tht but didnt help hun this is wat log said ive had to copy u paste as it wouldnt let me upload
    +++++++++++++++ DAZ Studio 4.6.0.18 starting +++++++++++++++++
    Platform bits: 32
    Qt Version: 4.8.4
    Running on Windows 7, Build 7601, Service Pack 1
    CPU Information:
    CPU String: GenuineIntel
    CPU Brand String: Celeron(R) Dual-Core CPU T3100 @ 1.90GHz
    Cache Line Size = 64
    L2 Associativity = 4
    Cache Size = 1024
    Stepping ID = 10
    Model = 7
    Family = 6
    Extended model = 1
    CLFLUSH cache line size = 64
    APIC Physical ID = 1
    Supported CPU Features:
    SSE3 New Instructions
    MONITOR/MWAIT
    CPL Qualified Debug Store
    Thermal Monitor 2
    x87 FPU On Chip
    Virtual-8086 Mode Enhancement
    Debugging Extensions
    Page Size Extensions
    Time Stamp Counter
    RDMSR and WRMSR Support
    Physical Address Extensions
    Machine Check Exception
    CMPXCHG8B Instruction
    APIC On Chip
    SYSENTER and SYSEXIT
    Memory Type Range Registers
    PTE Global Bit
    Machine Check Architecture
    Conditional Move/Compare Instruction
    Page Attribute Table
    Page Size Extension
    CFLUSH Extension
    Debug Store
    Thermal Monitor and Clock Ctrl
    MMX Technology
    FXSAVE/FXRSTOR
    SSE Extensions
    SSE2 Extensions
    Self Snoop
    Hyper-threading Technology
    Thermal Monitor
    Pend. Brk. EN.
    Physical Memory:
    Total: 2.9 GB (3119435776)
    Avail: 1.3 GB (1423654912)
    Virtual Memory:
    Total: 1.9 GB (2147352576)
    Avail: 1.8 GB (1974132736)
    Current Memory Usage: 54%
    Current DateTime:
    Loc: Fri 26. Jul 01:40:59 2013
    UTC: Fri 26. Jul 00:40:59 2013
    Temp Data:
    Location = C:/Users/paula/AppData/Roaming/DAZ 3D/Studio4/temp
    Disk Total: 931.4 GB (1000097181696)
    Disk Avail: 727.0 GB (780620333056)
    Locale: en_GB
    No translator found.
    Reading style definition C:/Program Files/DAZ 3D/DAZStudio4/resources/style/Darkside.style
    Creating managers
    Reading help index
    Reading help file C:/Program Files/DAZ 3D/DAZStudio4/docs/DAZ Studio/DAZStudioHelp.dsx
    Reading help file C:/Program Files/DAZ 3D/DAZStudio4/docs/inlinehelp.dsx
    Scanning import folders
    Scanning content folders
    Using GLEW 1.9.0
    Supported OpenGL extensions:
    GL_EXT_blend_minmax
    GL_EXT_blend_subtract
    GL_EXT_blend_color
    GL_EXT_abgr
    GL_EXT_texture3D
    GL_EXT_clip_volume_hint
    GL_EXT_compiled_vertex_array
    GL_SGIS_texture_edge_clamp
    GL_SGIS_generate_mipmap
    GL_EXT_draw_range_elements
    GL_SGIS_texture_lod
    GL_EXT_rescale_normal
    GL_EXT_packed_pixels
    GL_EXT_texture_edge_clamp
    GL_EXT_separate_specular_color
    GL_ARB_multitexture
    GL_EXT_texture_env_combine
    GL_EXT_bgra
    GL_EXT_blend_func_separate
    GL_EXT_secondary_color
    GL_EXT_fog_coord
    GL_EXT_texture_env_add
    GL_ARB_texture_cube_map
    GL_ARB_transpose_matrix
    GL_ARB_texture_env_add
    GL_IBM_texture_mirrored_repeat
    GL_EXT_multi_draw_arrays
    GL_NV_blend_square
    GL_ARB_texture_compression
    GL_3DFX_texture_compression_FXT1
    GL_EXT_texture_filter_anisotropic
    GL_ARB_texture_border_clamp
    GL_ARB_point_parameters
    GL_ARB_texture_env_combine
    GL_ARB_texture_env_dot3
    GL_ARB_texture_env_crossbar
    GL_EXT_texture_compression_s3tc
    GL_ARB_shadow
    GL_ARB_window_pos
    GL_EXT_shadow_funcs
    GL_EXT_stencil_wrap
    GL_ARB_vertex_program
    GL_EXT_texture_rectangle
    GL_ARB_fragment_program
    GL_EXT_stencil_two_side
    GL_ATI_separate_stencil
    GL_ARB_vertex_buffer_object
    GL_EXT_texture_lod_bias
    GL_ARB_occlusion_query
    GL_ARB_fragment_shader
    GL_ARB_shader_objects
    GL_ARB_shading_language_100
    GL_ARB_texture_non_power_of_two
    GL_ARB_vertex_shader
    GL_NV_texgen_reflection
    GL_ARB_point_sprite
    GL_EXT_blend_equation_separate
    GL_ARB_depth_texture
    GL_ARB_texture_rectangle
    GL_ARB_draw_buffers
    GL_ARB_color_buffer_float
    GL_ARB_half_float_pixel
    GL_ARB_texture_float
    GL_ARB_pixel_buffer_object
    GL_EXT_framebuffer_object
    GL_ARB_draw_instanced
    GL_ARB_half_float_vertex
    GL_EXT_draw_buffers2
    GL_WIN_swap_hint
    GL_EXT_texture_sRGB
    GL_EXT_packed_float
    GL_EXT_texture_shared_exponent
    GL_ARB_texture_rg
    GL_ARB_texture_compression_rgtc
    GL_NV_conditional_render
    GL_EXT_texture_swizzle
    GL_ARB_framebuffer_sRGB
    GL_EXT_packed_depth_stencil
    GL_ARB_depth_buffer_float
    GL_EXT_transform_feedback
    GL_EXT_framebuffer_blit
    GL_ARB_vertex_array_object
    WGL_EXT_depth_float
    WGL_ARB_buffer_region
    WGL_ARB_extensions_string
    WGL_ARB_make_current_read
    WGL_ARB_pixel_format
    WGL_ARB_pbuffer
    WGL_EXT_extensions_string
    WGL_EXT_swap_control
    WGL_ARB_pixel_format_float
    WGL_ARB_framebuffer_sRGB
    : NOT INITIALIZED
    OpenGL features for current hardware:
    OpenGL provider: Intel
    OpenGL renderer: Mobile Intel(R) 4 Series Express Chipset Family
    OpenGL version: 2.1.0
    Maximum number of lights: 16
    Number of auxiliary buffers: 0
    Number of texture units: 8
    Depth buffer bit resolution: 24
    Maximum OpenGL texture size: 4096 x 4096
    Current OpenGL Texture Quality Setting: Good Performance
    RGBA color bitplane resolutions: 8 8 8 8
    GLSL version: 1.20 - Intel Build 8.15.10.2302
    Shadow mapping supported
    VBO supported
    WARNING: dzvalentinaobjectdatabase.cpp(38): DB Register Open error: Cannot establish VC_Connection with remote server.
    Make sure the server address and port number are correct.
    *** Scene Cleared ***
    Loading plug-ins:
    aniMate2.dll
    dazscriptide.dll
    dz3dbridge.dll
    dz3dconnexion.dll
    dz3dmouse.dll
    dzalignace.dll
    dzassetiofilters.dll
    dzautofit.dll
    dzautoriggercontrol.dll
    dzautoshaderbakeractions.dll
    dzbrycebridge.dll
    dzbvh.dll
    dzcolladax.dll
    dzcomponents.dll
    dzcontentdbeditor.dll
    dzcontentlibrarypane.dll
    dzcr2exporter.dll
    dzcustomizedlg.dll
    dzdecimator.dll
    dzdelightrenderer.dll
    dzdformeditor.dll
    dzeasyloader.dll
    dzexpexporter.dll
    dzfbxexporter.dll
    dzfbximporter.dll
    dzfiguresetup.dll
    dzgoz.dll
    dzhexagonbridge.dll
    dzimageio.dll
    dzjointeditor.dll
    dzlayerededitor.dll
    dzlayerfilter.dll
    dzmanualshaderbaker.dll
    dzmaptransfer.dll
    dzmorphfollower.dll
    dzmorphloader.dll
    dzmorphloaderpro.dll
    dzobjexporter.dll
    dzoptitexclothcontrol.dll
    dzpolygongroupeditortool.dll
    dzprimitives.dll
    dzpropertyeditor.dll
    dzpuppeteer.dll
    dzpz3importer.dll
    dzrenderedit.dll
    dzrenderlibrary.dll
    dzrslshadercompiler.dll
    dzsavefilters.dll
    dzscriptedrenderer.dll
    dzscriptedsteps.dll
    dzshaderbaker.dll
    dzshaderbuilder.dll
    dzshadereditor.dll
    dzshadermixerbase.dll
    dzshadermixergui.dll
    dzsmartcontentpane.dll
    dzspotrendertool.dll
    dztextureatlas.dll
    dztransferutility.dll
    dzu3dexporter.dll
    dzweightmapbrush.dll
    dzwinvideo.dll
    lamhPlugin.32.dll
    mcjColliderDS45.dll
    mcjWarpDS45x32.dll
    sdk_sceneinfopane.dll
    dzmimicbasic.dll
    dzmimicrealtime.dll
    dzpowerpose.dll
    WARNING: QLayout: Attempting to add QLayout "" to QWidget "", which already has a layout
    Could not activate Dynamic Cloth Plugin - Control evaluation. Plug-in disabled.
    Could not activate Mimic Live! evaluation. Plug-in disabled.
    Total class factories: 1221
    WARNING: 3DConnexion Plug-in Error: Could not create Device, CoCreateInstance failed
    3D mouse support library could not be loaded.
    Creating interface
    Successfully created OpenGL viewport for Viewport1.
    Successfully created OpenGL viewport for Viewport2.
    Successfully created OpenGL viewport for Viewport3.
    Successfully created OpenGL viewport for Viewport4.
    WARNING: QFile::flush: No file engine. Is IODevice open?
    WARNING: QWidget::setMinimumSize: (mcjWarpPane log/Q3TextBrowser) Negative sizes (320,-1) are not possible
    Executing startup script...
    Started in: C:/Program Files/DAZ 3D/DAZStudio4
    DAZ Studio Started
    Creating Pixel Buffer
    Pixel buffer - Width: 1024 Height: 1024
    Compiling OpenGL Shader...
    Fragment Shader:
    No errors.Fragment Shader compiled successfully.
    Linking Shader:
    No errors.Shader Program successfully linked.
    Loading Startup Scene : C:/Users/paula/Documents/Daz 3D/Studio/My Library/People/Genesis/Genesis.duf
    File loaded in 0 min 6.4 sec.
    Loaded file: Genesis.duf
    File loaded in 0 min 3.9 sec.
    Loaded file: Dawn.duf
    Ran tdlmake on image C:/Users/paula/Documents/DAZ 3D/Studio/My Library/Runtime/Textures/HiveWire 3D/Dawn/2_DawnMouth.jpg
    Ran tdlmake on image C:/Users/paula/Documents/DAZ 3D/Studio/My Library/Runtime/Textures/HiveWire 3D/Dawn/2_DawnMouthB.jpg
    Ran tdlmake on image C:/Users/paula/Documents/DAZ 3D/Studio/My Library/Runtime/Textures/HiveWire 3D/Dawn/2_DawnMouthS.jpg
    Ran tdlmake on image C:/Users/paula/Documents/DAZ 3D/Studio/My Library/Runtime/Textures/HiveWire 3D/Dawn/1_DawnEyes.jpg
    Ran tdlmake on image C:/Users/paula/Documents/DAZ 3D/Studio/My Library/Runtime/Textures/HiveWire 3D/Dawn/1_DawnEyesB.jpg
    Ran tdlmake on image C:/Users/paula/Documents/DAZ 3D/Studio/My Library/Runtime/Textures/HiveWire 3D/Dawn/4_DawnLashes.jpg
    Importing File...
    Reading frill pants.obj
    Imported: frill pants.obj
    Time to load file: 1441.09 ms
    Building Scene...
    File loaded in 0 min 5.2 sec.
    Loaded file: frill pants.obj
    Ran tdlmake on image C:/Users/paula/Documents/DAZ 3D/Studio/My Library/Runtime/Textures/HiveWire 3D/Dawn/3A_DawnArmsB.jpg
    Ran tdlmake on image C:/Users/paula/Documents/DAZ 3D/Studio/My Library/Runtime/Textures/HiveWire 3D/Dawn/3A_DawnArms.jpg
    Ran tdlmake on image C:/Users/paula/Documents/DAZ 3D/Studio/My Library/Runtime/Textures/HiveWire 3D/Dawn/3A_DawnArmsS.jpg
    Ran tdlmake on image C:/Users/paula/Documents/DAZ 3D/Studio/My Library/Runtime/Textures/HiveWire 3D/Dawn/3B_DawnLegs.jpg
    Ran tdlmake on image C:/Users/paula/Documents/DAZ 3D/Studio/My Library/Runtime/Textures/HiveWire 3D/Dawn/3B_DawnLegsB.jpg
    Ran tdlmake on image C:/Users/paula/Documents/DAZ 3D/Studio/My Library/Runtime/Textures/HiveWire 3D/Dawn/3C_DawnTorsoB.jpg
    Ran tdlmake on image C:/Users/paula/Documents/DAZ 3D/Studio/My Library/Runtime/Textures/HiveWire 3D/Dawn/3B_DawnLegsS.jpg
    Ran tdlmake on image C:/Users/paula/Documents/DAZ 3D/Studio/My Library/Runtime/Textures/HiveWire 3D/Dawn/3C_DawnTorso.jpg
    Ran tdlmake on image C:/Users/paula/Documents/DAZ 3D/Studio/My Library/Runtime/Textures/HiveWire 3D/Dawn/3C_DawnTorsoS.jpg
    Ran tdlmake on image C:/Users/paula/Documents/DAZ 3D/Studio/My Library/Runtime/Textures/HiveWire 3D/Dawn/5_DawnNails.jpg
    Ran tdlmake on image C:/Users/paula/Desktop/dawn/frill pants.jpg
    Ran tdlmake on image C:/Users/paula/Documents/DAZ 3D/Studio/My Library/Runtime/textures/HiveWire 3D/Dawn/3_DawnFaceB.jpg
    Ran tdlmake on image C:/Users/paula/Documents/DAZ 3D/Studio/My Library/Runtime/Textures/HiveWire 3D/Dawn/3_DawnFace.jpg
    Ran tdlmake on image C:/Users/paula/Documents/DAZ 3D/Studio/My Library/Runtime/Textures/HiveWire 3D/Dawn/3_DawnFaceS.jpg
    WARNING: QEventDispatcherWin32::unregisterTimer: invalid argument
    Rendering image
    Compiled C:/Users/paula/AppData/Roaming/DAZ 3D/Studio4/shaders/brickyard/{ea998153-70a1-4a60-9864-f9168d7513cb}/shader_Surface.sdl...
    Created RenderCacheBlock
    Render Cancelled
    Rendering image
    Render Cancelled
    Rendering image
    Finished Rendering
    Rendering image
    Finished Rendering
    Rendering image
    Render Cancelled
    Rendering image
    Render Cancelled
    Rendering image
    Render Cancelled
    Rendering image
    Finished Rendering
    Rendering image
    Saved image: C:\Users\paula\AppData\Roaming\DAZ 3D\Studio4\temp\render\r.png
    Render Cancelled
    Total Rendering Time: 1 minutes 15.73 seconds
    Importing File...
    Reading frilltop.obj
    Imported: frilltop.obj
    Time to load file: 4029.89 ms
    Building Scene...
    File loaded in 0 min 12.7 sec.
    Loaded file: frilltop.obj
    Ran tdlmake on image C:/Users/paula/Desktop/dawn/frilltop.jpg
    Rendering image
    Render Cancelled
    Total Rendering Time: 45.14 seconds
    Rendering image
    Finished Rendering
    Total Rendering Time: 5 minutes 11.46 seconds
    Saved image: C:\Users\paula\AppData\Roaming\DAZ 3D\Studio4\temp\RenderAlbumTmp\Render 1.jpg
    Performing figure transfer:
    Empty URI for node during figure/prop asset save.
    Saved image: C:\Users\paula\Documents\Daz 3D\Studio\My Library\Figures\frill dream\ff frill top.duf.png
    Platform bits: 32
    Qt Version: 4.8.4
    CPU Information:
    Cache Size = 1024
    Stepping ID = 10
    Model = 7
    Family = 6
    Extended model = 1
    MONITOR/MWAIT
    Thermal Monitor 2
    x87 FPU On Chip
    Time Stamp Counter
    APIC On Chip
    PTE Global Bit
    Page Size Extension
    CFLUSH Extension
    Debug Store
    MMX Technology
    FXSAVE/FXRSTOR
    SSE Extensions
    SSE2 Extensions
    Self Snoop
    Thermal Monitor
    Pend. Brk. EN.
    Physical Memory:
    Avail: 1.9 GB (2128519168)
    Virtual Memory:
    Current Memory Usage: 31%
    Current DateTime:
    Loc: Fri 26. Jul 03:18:30 2013
    UTC: Fri 26. Jul 02:18:30 2013
    Temp Data:
    Disk Avail: 728.1 GB (781830127616)
    Locale: en_GB
    Creating managers
    Reading help index
    Using GLEW 1.9.0
    GL_EXT_blend_minmax
    GL_EXT_blend_color
    GL_EXT_abgr
    GL_EXT_texture3D
    GL_SGIS_texture_lod
    GL_ARB_multitexture
    GL_EXT_bgra
    GL_EXT_fog_coord
    GL_NV_blend_square
    GL_ARB_shadow
    GL_ARB_window_pos
    GL_EXT_shadow_funcs
    GL_EXT_stencil_wrap
    GL_ARB_point_sprite
    GL_ARB_draw_buffers
    GL_WIN_swap_hint
    GL_EXT_texture_sRGB
    GL_EXT_packed_float
    GL_ARB_texture_rg
    WGL_EXT_depth_float
    WGL_ARB_pbuffer
    : NOT INITIALIZED
    VBO supported
    Loading plug-ins:
    aniMate2.dll
    dazscriptide.dll
    dz3dbridge.dll
    dz3dconnexion.dll
    dz3dmouse.dll
    dzalignace.dll
    dzautofit.dll
    dzbrycebridge.dll
    dzbvh.dll
    dzcolladax.dll
    dzcomponents.dll
    dzcr2exporter.dll
    dzcustomizedlg.dll
    dzdecimator.dll
    dzdformeditor.dll
    dzeasyloader.dll
    dzexpexporter.dll
    dzfbxexporter.dll
    dzfbximporter.dll
    dzfiguresetup.dll
    dzgoz.dll
    dzhexagonbridge.dll
    dzimageio.dll
    dzjointeditor.dll
    dzlayerededitor.dll
    dzlayerfilter.dll
    dzmaptransfer.dll
    dzmorphfollower.dll
    dzmorphloader.dll
    dzobjexporter.dll
    dzprimitives.dll
    dzpuppeteer.dll
    dzpz3importer.dll
    dzrenderedit.dll
    dzrenderlibrary.dll
    dzsavefilters.dll
    dzscriptedsteps.dll
    dzshaderbaker.dll
    dzshaderbuilder.dll
    dzshadereditor.dll
    dztextureatlas.dll
    dzu3dexporter.dll
    dzwinvideo.dll
    lamhPlugin.32.dll
    mcjColliderDS45.dll
    mcjWarpDS45x32.dll
    dzmimicbasic.dll
    dzmimicrealtime.dll
    dzpowerpose.dll
    Creating interface
    DAZ Studio Started
    Fragment Shader:
    Linking Shader:
    File loaded in 0 min 3.4 sec.
    File loaded in 0 min 2.1 sec.
  • TotteTotte Posts: 15,135
    @fairyfantastic:
    It's the end of the file that is interesting, where it actually crashes, please post the last 100 lines or so.
    : NOT INITIALIZED
    Current OpenGL Texture Quality Setting: High Quality
    VBO supported
    Loading plug-ins:
    aniMate2.dll
    dazscriptide.dll
    dz3dbridge.dll
    dz3dconnexion.dll
    dz3dmouse.dll
    dzalignace.dll
    dzautofit.dll
    dzbrycebridge.dll
    dzbvh.dll
    dzcolladax.dll
    dzcomponents.dll
    dzcr2exporter.dll
    dzcustomizedlg.dll
    dzdecimator.dll
    dzdformeditor.dll
    dzeasyloader.dll
    dzexpexporter.dll
    dzfbxexporter.dll
    dzfbximporter.dll
    dzfiguresetup.dll
    dzgoz.dll
    dzhexagonbridge.dll
    dzimageio.dll
    dzjointeditor.dll
    dzlayerededitor.dll
    dzlayerfilter.dll
    dzmaptransfer.dll
    dzmorphfollower.dll
    dzmorphloader.dll
    dzobjexporter.dll
    dzprimitives.dll
    dzpuppeteer.dll
    dzpz3importer.dll
    dzrenderedit.dll
    dzrenderlibrary.dll
    dzsavefilters.dll
    dzscriptedsteps.dll
    dzshaderbaker.dll
    dzshaderbuilder.dll
    dzshadereditor.dll
    dztextureatlas.dll
    dzu3dexporter.dll
    dzwinvideo.dll
    lamhPlugin.32.dll
    mcjColliderDS45.dll
    mcjWarpDS45x32.dll
    dzmimicbasic.dll
    dzmimicrealtime.dll
    dzpowerpose.dll
    Creating interface
    DAZ Studio Started
    Fragment Shader:
    Linking Shader:
    here u go totte
