Missing Genesis 2 Female file?
Ok, so I updated my Daz to 4.6 and I'm enjoying it. But every time I try to load in the new Genesis 2 Female base it keeps telling me that it's missing a file! D:
/data/DAZ 3D/Genesis 2/Female/Genesis2Female.dsf
Does anyone know where I can find this damned file?! I downloaded everything using the download manager. I've uninstalled G2 and reinstalled it a couple times now yet it's still happening. I'm stuck with what to do D:
If you downloaded and installed using the DIM (DAZ Install Manager), your content may not be where you think it is.
The DIM, by default, installs to C:\Users\Public\Documents\My DAZ 3D Library
You need to make sure that path is listed as both DAZ Studio AND Poser Formats in the Content Directory Manager. (Edit > Preferences > Content Library > Content Directory Manager)
If you want your content installed to another folder, you will need to add the new install path to the DIM by using the little gear icon at the top right of the interface. You should also read the Help files for DIM before using it.
Now why is it I don't use DIM?
Seriously I don't use DIM or CMS and don't have these issues; that I read about on the forum all the time.
I download the zip; if DAZ has updated the content to have a zip, and do it manually.
Note: The zips for older content are for Macs not PCs. Much of the older content is still in DAZ installers; which I hate.
