My M4 wants to wear a Hawaiian shirt. Anyone seen one for him?
raindog308raindog308 Posts: 0
I can't seem to find a Hawaiian shirt (like Tommy Bahama) for M4. Or really for anything.
I swear about 50% of middle aged Americans wear them...including me :-)
Has anyone seen a clothing pack with Hawaiian shirts for M4?
  • vwranglervwrangler Posts: 5,048
    edited July 2013
    Similar thread from a couple of weeks ago.
    There just isn't that much out there for that product niche.
    One other thing you could try would be using a floral texture from Fabricator or some such on Cold Life. (I have no idea what's "cold" about a short sleeved shirt, but whatever.)
    Post edited by vwrangler on
  • ByrdieByrdie Posts: 1,783
    edited July 2013
    If you have the excellent M4 Bad Guy outfit, grab the ones from this thread: http://www.daz3d.com/forums/discussion/22032/
    They also work with the Genesis version.
    Post edited by Byrdie on
  • LillianaLilliana Posts: 105
    edited July 2013
    Palm by Prae over at Renderosity
    http://www.renderosity.com/mod/bcs/palm-for-m4-h4/86113
    Even comes with the textures and shorts.
    Maybe a Niche market, but there is quite a bit of content if you know where to look.
    Post edited by Lilliana on
  • FirstBastionFirstBastion Posts: 8,076
    edited July 2013
    Stylin' might work, again with one of fabricator's floral shaders http://www.daz3d.com/catalogsearch/result/?q=fabricator
    http://www.daz3d.com/stylin-for-m4
    needs a shirt geometry meticulously uvmapped so a detailed print wouldn't have distortions
  • IceEmpressIceEmpress Posts: 639
    edited July 2013
    I'm at least looking for a hawaiian friuit shirt texture for some freebie product. But I don't even see that.
    Hell, I don't even know where to look for a Hawaiian fruit shirt seamless texture in order to try making one myself!
    Post edited by IceEmpress on
  • LindseyLindsey Posts: 2,017
    Simplest way is to texture a shirt with a seamless tile.
    1. Use a search engine for Hawaiian Shirt Seamless texture.
    2. Set the texture in the diffuse channel of the shirt's material zones.
    3. Set the Horizontal Tile and Vertical Tile value to 5 for both as a starting point. Different values will alter the pattern size.
    Here's a sample using the Stylin for M4 Over shirt. This shirt only has one material zone.
    If the shirt has multiple material zones, you may need to adjust each material zone's horizontal and vertical tile settings to have a consistent pattern size across all material zones.
    1347 x 929 - 201K
  • WendyLuvsCatzWendyLuvsCatz Posts: 41,577
    why does it need to be seamlessly uv mapped on seams?
    none of the clothes in my real life wardrobe are
    the fabric itself can be easily made seamsles in say Gimp under filters, map, make seamless
    (or presumably in photoshop if you have it)
    you can find an image of a palm tree and a hibiscus flower, erase the background with erase brush and just use them as brushes to stamp a fabric too.
    edited July 2013
    I started out my post with "Simplest way is to texture a shirt with a seamless tile." Which looks best, but if one doesn't care if the pattern doesn't match, then it doesn't need to be seamless of course. Note that no one posted reply to this thread since the last 10 hours.
    Post edited by Lindsey on
    I have not looked at forum for well over 10 hours
    this came up in new topic search
    just added my 2 cents
