Nipple poking through in some clothing
Whats the best way to remove poke through in clothing?  The piece I'm talking about has dforce but it does it in others as well.  Is there an easy fix?
    Dial the nipple morph down to zero, under the Parameters tab. Hide the breast area, unless the clothing is low cut. Expand the clothing item, either with scaling, or using in-built morphs. It would help if you could tell us what figure and clothing you are using, then we can be more specific smiley
  • y3kmany3kman Posts: 877
    A dforce simulation turns off the mesh smoothing of the clothes. Try turning it on again. If it's on, just dial down the nipple morph.
  • Prince WaoPrince Wao Posts: 373
    I've had this problem a lot as being a writer I love creating new characters and they must all have unique bodies. With the Genesis 2 female (still my favourite) you can remove the nipples in Materials, but it doesn't always clear the poke through. So when the nipple is too prominent for the outfit I just re-morph the breasts as no-one is going to spot that the breasts are slightly different under two different outfits.
  • wsgentrywsgentry Posts: 573
    I don't know if Fit Control works with dForce, but I've used it on clothing where the stock adjustments don't cut it.
    Scott
