My files doesn't lod texture any more. Why?
My v4.2 and m4 was working fine today until i was following a tutorial about editing the texture of the figure in which i have had open v4.2 .cr2 file in text editor to know where the actual figure is located but after that all poser file loads in daz with no skin just the silver object with no color on it
any idea about what that might be ?
Doesn't sound like you were just looking but actually edited the file. Did you check the paths? commas instead of periods ... headed for the same Runtime ... jpg/png ...
Might be easiest to simply reinstall the product and in the future "always" work on a copy. If can be in the same folder and if it works as intended will work as the original plus whatever changes were made.
Thanks a lot reinstalling worked
i removed the files manually and reinstalled v4.2 again and it worked
thanks
You're welcome, glad you got it working again.
To just change textures, rather than manually editing files, we can change images/colours/etc on the Surface Tab, then save out a "materials preset". Creates a new file that does not change the original. In D/S these mats are saved to a folder in My Library [not in the Runtime].
