Started 4.6, now nothing in my actor pane
Loaded 4.6 once I realized daz doesn't have a notice for when a new version is out :roll: Then when I get it installed, all the stuff is gone from my smart content, shaping, etc, absolutely nothing. How do I fix this?
Smart Content relies on the Content Management Service (CMS) to be running, have you checked that it is running.
Does your content appear in the Content Library pane, and what version of DAZ Studio were you using prior to installing 4.6?
If you did not Un-install the old CMS before you Upgraded the DAZ Studio your using the old CMS that might not talk to DS properly. The CMS has been updated as well but is not Removed/Updated when you Update DS. I would just Un-install the CMS and then run the DS installer again. That only over writes and Add's the New CMS without changing any of your settings.
