tiger/cat texture set for G8
kaotkblisskaotkbliss Posts: 2,918
Is there a texture set for G8 for a tiger or cat, preferably toon style?
I saw rawart has a set but from the promos the patterns don't hardly show up at all.
  • jedijuddjedijudd Posts: 606
    There is this its not a tiger though, and it can be used on G8
    https://www.daz3d.com/cheetah-girl-for-genesis-3-female
  • Bunyip02Bunyip02 Posts: 9,338
    edited June 2018
    Front view of RawArts M4 Catworld Tiger converted with Blacksmith 3D Texture Converter to G3M then applied to G8M
    Rear view of RawArts M4 Catworld Tiger converted with Blacksmith 3D Texture Converter to G3M then applied to G8M
    Front view of RawArts G8M Catworld Tiger skin
    Rear view of RawArts G8M Catworld Tiger skin, note patch where the tail goes.
    1993 x 1029 - 571K
    1978 x 1037 - 572K
    1991 x 1023 - 569K
    1982 x 1037 - 570K
    Post edited by Bunyip02 on
    edited June 2018
    https://www.daz3d.com/cat-world-for-genesis-8-female-s
    You can use the textures without the LAMH preset. Is this the one you mentioned as the patterns not showing?
    Here's the texture on Sakura 8.
    Give me a few minutes and I'll render the tiger version under an Iray skydome.
    470 x 676 - 229K
    Post edited by frankrblow on
    edited June 2018
    Okay, here's the tiger version, with no posing of limbs, just added basic wear and Iray Worlds. Would this texture help you?
    1600 x 2589 - 6M
    edited June 2018
    https://www.daz3d.com/catgirl-for-aiko-4-and-victoria-4
    Converted from V4 to G3F using Blacksmith 3D Texture Transformer then applied to G8F
    1989 x 1033 - 609K
    1980 x 1025 - 601K
    1987 x 1035 - 547K
    1982 x 1014 - 532K
    edited June 2018
    https://www.daz3d.com/catgirl-for-aiko-3
    https://www.daz3d.com/texture-convertor-2-tc2-bundle
    Converted from V3/A3 to V4 with TC2, then converted from V4 to G3F using Blacksmith 3D Texture Transformer, then applied to G8F
    1978 x 1029 - 569K
    1980 x 1033 - 546K
    1989 x 1035 - 570K
    1983 x 1031 - 532K
  • kaotkblisskaotkbliss Posts: 2,918
    Wow! Thank you all :)
    Looks like I have some options (and apparently some products to get LOL)
  • ermullensermullens Posts: 93
    There's a female one can be converted with blacksmith transformer from Gen 2 has 3 different variations of markings https://www.daz3d.com/tigerlily-bundle/
  • Lyrra MadrilLyrra Madril Posts: 284
    Look at the skins for Melody 2 - Melody 2 is a pop top head character for V4, but the body is all V4. So anything that can use v4 skins should be able to use the Melody 2 skins
    edited June 2018
    Melody 2 uses a head cr2 file that the head material needs to be applied to. When you apply the body texture you get everything except for the head.
    1979 x 1033 - 563K
