Any control over the moist line of the eyes?
SylvanSylvan Posts: 2,719
My eyes are looking quite flat because I am unable to get a good grip on the wet waterline of G8. On some characters it doesn't even seem to be there at all. I am talking about the thin line of moisture that rests on the lower eyelids. The eyes of the guy in my signature also has a little watershimmer on the lower eyelid. I haven't been able to produce anything like that with G8 so far. Am I missing something?
  • xyer0xyer0 Posts: 6,507
    There is an Eye Moisture surface in the Eyelashes. You access it in the Surfaces tab.
  • GoggerGogger Posts: 2,533
    If you select the 'Surface Selection Tool' (ALT + Shift + M) and then click on the model's eyes where the eye moisture is you can usually get it to show and once selected reduce the 'Cutout Opacity' in the Surfaces tab down to whatever you like, I usually use something like 14 - 24% depending on the model and lighting.
  • SylvanSylvan Posts: 2,719
    edited June 2018
    Thank you Gogger and xyer0! I finally figured it out, Woohoo :D
    Post edited by Sylvan on
