Gen X2 help - nevermind. Solved.
DaWaterRat
Nevermind. I found where I needed to switch things. The connect library wasn't setup correctly.
Greetings.
I want to move some morphs from Genesis to Genesis 2 male using Generation X2. However, it is looking in the wrong data folder for what figures I have available, and cannot find either genesis or genesis 2 male. I've poked around and changed directories where I could, but no change. At this point, I'm not sure where or how I can tell it to look in the right spot - especially since I've started using Daz connect (which I'm suspecting may be part of the issue.)
I've used it successfully in the past, so I know that at one time everything was set up correctly. But now... it pretty much only wants to transfer from Genesis 2 female to Genesis 2 female.
