scene identification list is incomplete
Under the Scene Tab -> Edit -> Scene Identification, my list is underpopulated and doesn't list all the figures that I have installed into My Library.  I suspect that this is because I manually install most of my content.  Is there some way to manually add references to the Scene Identification list?
Thanks
  • Richard HaseltineRichard Haseltine Posts: 111,332
    As long as your manual install has ended up with them in the correct relative path within the content directory used, open the Content Library pane and then its option menu, by clicking the lined button in the top cornmer of the pane or by right-clicking the tab, and select Content DB Maintenance, then check Re-import Metadata, click Accept, then select all or the items you want in the next dialogue and click its Accept button.
  • Rascal3DRascal3D Posts: 290
    Awesome, Thanks Richard!
