DSON and Poser Error
pufflehuffpufflehuff Posts: 29
I've been getting this error when I attempt to install the DSON Importer for Poser:
Install Manager cannot find a required path. The installer for "DSON Importer for Poser (Win 64-bit)" requires that the installed path for "Poser Pro 2014;Pro 2012 (64-bit)" be defined. Make sure that a path for this application is present on the "Applications" page of the "Settings" dialog, then try again.
After trying to figure it out myself and do a little research...I'm just as lost as when I started.
I have PP 2012 and I believe I'm running the 32 bit version on a PC/Windows 7.
  • JaderailJaderail Posts: 0
    edited July 2013
    In the DIM open the Gear, select the Applications Tab, now Click the PLUS (lower left) in the Pop up Select the proper Version of Poser, then use the [...] to go to the path your Poser is installed to. Here is mine.
    583 x 579 - 84K
    Post edited by Jaderail on
  • pufflehuffpufflehuff Posts: 29
    THANK YOOOU. I would not have found that on my own.
    Cheers! n___n
