Objects move when parented
When I try to parent one object to another or to a charactwer, it moves position. It onlt started to do this recently; have I accidently changed some setting? If not how do I parent an object with it staying on the same place relative to the host object/character?
  • mlominymlominy Posts: 230
    When facing the same problem, I first parent the object to the character (like his hand), and then I position the object correctly. If I move the character, the object willl follow. And since it is already parented it will never move without my control.
  • Richard HaseltineRichard Haseltine Posts: 112,109
    If you want to keep the object in its current position you need to turn on Parent in Place. When using the Change Parent dialogue that's a box at the bottom, if you are using drag-and-drop in the Scene pane it's an entry in the Scene pane option menu - click the lined button in the top corner, or right-click the tab, and make sure that Parent in Place is checked.
  • Excellent, thank you. I knew there must be something somple
