question about updates on figures
Say that there is an update regarding a figure that you previously used.  If you pull up an old saved scene subset which includes the figure, is the update "pushed" to the scene subset or do you need to reload/redress/repose the figure if you want the most updated version?  I hope my question makes sense.
  • ALLIEKATBLUEALLIEKATBLUE Posts: 2,986
    Your question makes absolute sense and I wonder the same thing
  • frank0314frank0314 Posts: 15,116
    It depends on what's updated I would suppose.
  • Richard HaseltineRichard Haseltine Posts: 112,047
    Assuming we are talking about a native DS item in DSON format the saved files will be pointing to the assets unless you have customised them in some way (usually editing the geometry with the Geometry Editor tool will mean you are using a local version stored in the file, for example). If the scene is pointing back to the asset then yes, it will use the updated version of the asset if one is installed.
  • Worlds_EdgeWorlds_Edge Posts: 2,153
    Great, thanks Richard and Frank.
