Is there a way to make an HDRI render environment stay at a specific scale while zooming out?
Basically title. I downloaded this HDR a little while back and I've been trying to throw some primatives into a scene to act as guides for the HDRI for a scene I want to render but whenever I zoom out the HDRI scales up as well. I've never really used HDRIs too much so I'm pretty new at this. I've tried both infinite and finite dome (they don't look any different).
  • TooncesToonces Posts: 919
    edited June 2018
    Not that I'm aware of.
    However, zoom will affect the objects in the scene (much like scale), so you can use it to make them the correct relative sizes.
    I tend to have trouble with figure placement on HDRI ground plane when using non-Daz HDRIs, so I generally just use HDRI for out-of-focus backgrounds and/or lighting.
    Post edited by Toonces on
  • ChezjuanChezjuan Posts: 544
    You can try the dome radius setting. It's not automatic, but you can fiddle with the numbers after you zoom to (hopefully) get it to look the same relative size.
    You need to have it set on finite dome to do this.
