DIM Problem
rob.lesauteurrob.lesauteur Posts: 0
I have daz 3d install manager trying to install photoshop 3d bridge for Daz studio 4.5+ both 32 and 64 bit on my windows pc.
I get the following error:
Install Manager cannot find a required path. The installer for "Photoshop 3D Bridge for DAZ Studio 4.5+ (Win 64-bit)" requires that the installed path for "Photoshop CS6;CS5;CS4 (64-bit)" be defined. Make sure that a path for this application is present on the "Applications" page of the "Settings" dialog, then try again.
Thats for both editions. I have tried pointing the preferences to the photoshop/bridge and the daz 4.5 folders but it don't like any of them.
I have photoshop cs6 installed (both 32 and 64 bit editions)
any ideas ?
  • JaderailJaderail Posts: 0
    Mine Fails as well So I did Hand install, just DL it from My Account>My Programs. All Plugins still come as Exe's you can run yourself.
  • LindseyLindsey Posts: 2,016
    edited July 2013
    You need to tell DIM where your Photoshop program folder(s) are.
    1. Open DIM and click on the gear icon upper right
    2. Click on the Applications Tab
    3. Click the + button lower left and enter the Name (application), Version, Bit and path to the application's folder.
    Path example for my Photoshop CS6 64bit is C:\Program Files\Adobe\Adobe Photoshop CS6 (64 Bit)
    If you have both 64bit and 32bit versions of Photoshop installed, you need to setup the path to both. Note that both Daz Studio and Photoshop need to be the same bit to be able to "bridge" to each other.
    Post edited by Lindsey on
    I just did that, yep it Installed fine. As far as I can tell. At least it's not showing in DIM anymore. TY.
  • rob.lesauteurrob.lesauteur Posts: 0
    That worked perfectly, thanks very much :)
